Deprecated: Function create_function() is deprecated in /home/webroot/asrun.eu/support/include/parser.php on line 764
#1 2015-01-29 22:16:45
Tissendel
Membre
Soucis forum
Pourquoi je vois ça ?
C'est a chaque fois que je vais voir un post
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 789
Dernière modification par Tissendel (2015-01-29 22:17:54)
#2 2015-01-30 07:08:54
Freemaster
Responsable
Lieu : lamem
Re : Soucis forum
tout simplement parce que le forum est obsolète tongue
il faut patcher ton fichier parser.php, comme je l'ai fait pour le mien...
sinon c'est le serveur qui a été mise a  jour, avec les problèmes de sécurité, c'est obligé !
#3 2015-01-30 08:31:50
Tissendel
Membre
Re : Soucis forum
Comment qu'on fait pour le patcher ?
#4 2015-01-30 12:47:17
Freemaster
Responsable
Lieu : lamem
Re : Soucis forum
tu as toujours ce message ?
#5 2015-01-30 13:06:45
Tissendel
Membre
Re : Soucis forum
C'est pire je peux plus rien faire
J'ai des truc du genre :
Fatal error: Call to undefined function php55_callback() in /home/webroot/asrun.eu/kawanoblood/include/functions.php on line 2121
A chaque action
#6 2015-01-30 13:14:22
Freemaster
Responsable
Lieu : lamem
Re : Soucis forum
et là  ?
#7 2015-01-30 13:27:54
Tissendel
Membre
Re : Soucis forum
Tout semble marcher bien o/
Merci beaucoup big_smile
#8 2015-01-30 22:48:57
Tissendel
Membre
Re : Soucis forum
J'ai quand même un message quand je fait un post
Il semble pas poser de problème cependant.
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/parser.php on line 64 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/functions.php on line 1956 Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /home/webroot/asrun.eu/kawanoblood/include/functions.php on line 1956
#9 2015-01-30 22:53:27
Freemaster
Responsable
Lieu : lamem
Re : Soucis forum
et bien, faudrait mettre à jour fluxbb !
mais vu que tu as apporté des modifs sur la structure original, faudrait recommencer avec la nouvelle structure...
#10 2015-01-31 21:11:09
Tissendel
Membre
Re : Soucis forum
Ha oui, ça craint du boudin sad
#11 2015-02-01 11:09:10
Freemaster
Responsable
Lieu : lamem
Re : Soucis forum
si t'as juste modifié un thème, et non les fichiers du forum... une mise à jour est tout à fait possible...
mais est-ce le cas ?
