Deprecated: Function create_function() is deprecated in /home/webroot/asrun.eu/support/include/parser.php on line 764
#1 2007-03-19 14:08:14
SkaL
Membre
EXEPTION MESSAGE error code 0 et 2
le texte suivant apparaît lorsque je tente d'uploader des images dans un album, et égallement lorsque je clique sur "ressource" dans la centrale des ressources.
Exception message: mkdir(./gallery/115): Permission denied
Error code: 2
-- Backtrace --
/home/webroot/blog-libre.net/class/file/file.class.php(307): mkdir
/home/webroot/blog-libre.net/class/gallery/dao/galleryresourcestorage.class.php(133): file.createdir
/home/webroot/blog-libre.net/class/gallery/dao/galleryresourcestorage.class.php(151): galleryresourcestorage._checkuserstoragefolder
/home/webroot/blog-libre.net/class/action/admin/adminresourcesaction.class.php(45): galleryresourcestorage.checkuserstoragefolder
/home/webroot/blog-libre.net/class/action/admin/adminresourcesaction.class.php(61): adminresourcesaction.checkfolders
/home/webroot/blog-libre.net/class/controller/controller.class.php(309): adminresourcesaction.perform
/home/webroot/blog-libre.net/admin.php(39): admincontroller.process
Exception message: Could not create user storage folder for resources: ./gallery/115
Error code: 0
-- Backtrace --
/home/webroot/blog-libre.net/class/gallery/dao/galleryresourcestorage.class.php(134): throw
Exception message: Cannot modify header information - headers already sent by (output started at /home/webroot/blog-libre.net/class/object/exception.class.php:37)
Error code: 2
-- Backtrace --
/home/webroot/blog-libre.net/class/view/view.class.php(316): header
/home/webroot/blog-libre.net/class/view/admin/adminview.class.php(106): view.render
/home/webroot/blog-libre.net/class/view/admin/admintemplatedview.class.php(36): adminview.render
/home/webroot/blog-libre.net/class/controller/controller.class.php(329): adminerrorview.render
Error code: 2
-- Backtrace --
/home/webroot/blog-libre.net/class/view/view.class.php(177): header
/home/webroot/blog-libre.net/class/view/view.class.php(318): adminerrorview.sendcontenttype
It was not possible for LifeType to create the necessary folders where resources are going to be installed. This might be due to several reasons, such as your PHP installation running with safe mode enabled or your user not having enough permissions to do so. You may still try to carry out the operation manually, by creating the following folders:
./gallery/
./gallery/115/
./gallery/115/previews/
If these folders already exist please make sure that they can be read and written by the user running the web server.
Ce qui me chipote c'est que le dossier existe, et que je ne me rappelle pas avoir configuré une installation php.. je sais meme pas comment on fait !!
Et en ce qui concerne la solution proposée, je veux bien, mais je les créés où moi ces dossier??
So, si vous savez m'aider à resoudre ce problème...
Dernière modification par SkaL (2007-03-19 14:15:36)
#2 2007-03-19 15:30:08
Freemaster
Responsable
Lieu : lamem
Re : EXEPTION MESSAGE error code 0 et 2
en effet, un problème de droit sur un dossier... du au transfert de serveur...
réessayes, et redonnes les messages d'erreur, au cas où un autre dossier serait dans le même cas wink
#3 2007-03-29 22:55:14
SkaL
Membre
problème résolu, et je ne sais pas comment...
#4 2007-03-29 23:10:56
Katara
Membre
Lieu : Belgique
bah temps mieux alors smile
smileSite de Katarasmile
/!\ Veuillez garder la moindre des politesse sil' vous plais, Merci /!\
/!\ Veuillez editer vos messages et non du double poste, Merci /!\
